Engine cranks no start
120,000 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
BEN VENTURA
The whole distributor has been changed along with; crank sensor, spark plug wires, new battery, and new timing belt. is there a possibility that the new cam or coil came defective? is there a way to bench test them? fuel pump does not turn on i don't hear it prime. I checked all fuses and they are okay. please help.
Nov 20, 2020 at 3:00 AM
  • 110,251 POSTS
Ben, have you checked to see if you have spark to the plugs? Also, if you don't hear the fuel pump, it could be a fuel related issue. Take a look through this link and let me know if anything helps:
Try this: See if the engine starts for a couple of seconds when using starting fluid. If it does and then stalls, we have a fuel related issue.
Nov 20, 2020 at 10:54 AM
BEN VENTURA
thanks to Joe. Yes, I checked for spark and nothing. also I did put starting fluid it cranks but no start. the distributor is receiving12 volts in wire # 5 also ground in wire #6. thank you for your time and assistance.
Nov 24, 2020 at 9:54 AM
  • 110,251 POSTS
It sounds like the coil has failed, but to confirm, please follow these diagnostic directions. If the coil is bad, the distributor needs to be replaced. I will help with that if needed.
The attached pics below correlate with the diagnostics.
___________________________
2000 Nissan-Datsun Truck Pathfinder SE 2WD V6-3.3L (VG33E)
Component Tests and General Diagnostics
Vehicle Powertrain Management Ignition System Ignition Coil Testing and Inspection Component Tests and General Diagnostics
COMPONENT TESTS AND GENERAL DIAGNOSTICS
IGNITION COIL
1. Disconnect ignition coil harness connector.
see pic 1
see pic 2
See pic 3
2. Check resistance as shown in the figure.
For checking secondary coil, remove the distributor cap and measure resistance between coil tower metal tip 9 and terminal 7. If NG, replace distributor assembly as a unit.
Nov 24, 2020 at 11:26 AM
