Engine does not have power
180 MILES • 1.1L • 4 CYL • 2WD • MANUAL
ACKIM40
And also is not idling proper.
Jul 8, 2019 at 5:59 AM
Hi ACKIM40,
This sounds like a fuel issue. We need to check fuel pressure when idling and then while driving. If the pressure is low then most likely the pump or regulator are the issue.
Here is a guide on how to test the fuel pump. Let me know what you find and we can go from there.
Here is a guide that goes through more possible causes of low power. If the fuel pressure is okay then we need to go through this stuff next.
https://www.2carpros.com/articles/engine-has-low-power-output
Jul 8, 2019 at 6:19 AM
