My husband is trying to change the water pump and the last Bolt he has to get out wont come out.
VICKYP1
  • 1996 FORD WINDSTAR
  • 99,000 MILES
He has been spraying it over and over with lubricant and letting it sit. He uses a wrench to turn it back and forth so much so that he broke off the head. A friend gave him a device to "heat it up" in order to try and loosen it but it's hard to get to and so far it won't come out. What can he do?
Wednesday, June 26th, 2013 AT 1:16 PM
  • 109,885 POSTS
If he already broke the bolt, he will need to use something like vice grips to clamp onto what is still left. As far as the heat, it will help if you if you can heat the block around the bolt so it expands.
Saturday, August 15th, 2020 AT 10:34 AM
VICKYP1
The bolt is in a ford windstar front wheel drive 1996 van so it's difficult to get to?
  • 109,885 POSTS
I don't know why, but this just showed up in my mail. Sorry it has been so long. Have you had any luck with the issue?
