Engine shut off sitting at a red light, will not crank, nothing inside the car turns on
135,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
ABEL GONZALEZ
  • 7 POSTS
Last night at a red light car just shut off no crank, no lights, key stuck in ignition, no electric power at all. i checked the under hood fuse box and there is power getting to it and not emergency flashers. nothing in the car is coming on.
What can it be?
Please help!
Jun 28, 2019 at 3:27 AM
Good afternoon,
This sounds like the battery is dead. It would explain the no power.
My concern is if the charging system is working.
You need to charge the battery. Once you do that, the key will come out.
https://www.2carpros.com/articles/how-to-charge-your-car-battery
Jun 28, 2019 at 3:56 AM
ABEL GONZALEZ
  • 7 POSTS
Even when there is power at the fuse box?
Jun 28, 2019 at 4:29 AM
Yes. You need to start at the battery.
Jun 28, 2019 at 4:40 AM
ABEL GONZALEZ
  • 7 POSTS
Okay, thank you let me get a new battery and I'll get back with you.
Jun 28, 2019 at 5:06 AM
You are welcome.
always glad to help.
Jun 28, 2019 at 5:09 AM
ABEL GONZALEZ
  • 7 POSTS
Asemaster6371,
I put a new battery on it and still nothing.
Jun 28, 2019 at 11:40 AM
Good morning,
Can you test for voltage to the ignition switch? I need to know if power is getting there.
I also attached some checks for the power. Check the 50 amp fuse at the battery for power on both sides which feeds the BCM.
Jun 28, 2019 at 10:00 PM
ABEL GONZALEZ
  • 7 POSTS
Asermaster6371,
A very good morning to you Sir.
Problem solved.
I replaced the fuse box under the dashboard passengers side and we are back on business.
Thank you for all your help.
Jul 1, 2019 at 2:20 AM
You are welcome.
Always glad to help.
Jul 1, 2019 at 2:21 AM
