My heater is not working
1,000,000 MILES • 2.7L • 6 CYL • 2WD • AUTOMATIC
LUIS CORTS
They have flushed all those systems and still not working.
Jan 9, 2022 at 6:30 AM
SQM
  • 6,383 POSTS
There are a few reasons why the heater might not work. It can be due to the engine not warming up properly due to stuck open thermostat. Also, it could be due to a faulty blend door actuator that is stuck on the cold setting.
Take a look at this guide, see if you might have overlooked something:
https://www.2carpros.com/articles/car-heater-not-working
The blend door actuator controls the hot/cold air flow or mix. It can fail and get stuck in either hot or cold position. If it is stuck in the cold position the heat will not function.
Jan 9, 2022 at 7:12 AM
