my heater blowing cold air n a/ c not very cold had freon ckd n its ful
290,000 MILES
SLAMMINS
My main concern is heater blowing cold air I'm in Tn. And its already cold out what causes that? Fan working great this summer my air never really got cold either had freon ckd n it was ok o please reply asap as I'm freezing to n from work
Oct 22, 2013 at 8:38 AM
TY ANDERSON
  • 719 POSTS
First I would check the cabin air filter for restriction. If this filter is not restricted. I would suspect one of the doors that controls the temperature. For example if the temperature blend door is open half way (or broken preventing the stepper motor that controls the door from moving the door) it's not going to blow very cold or very hot because both hot and cold temperatures are mixing.
Have the climate control module scanned for fault codes. This will give you a starting point if there is a malfunction detected within the climate control.
Let me know what you find. TY
Oct 26, 2013 at 7:21 PM
