The fuel valve has fallen into the diesel fuel tank?
132,000 MILES • 2WD • MANUAL
CAMERONCLIO
When I went to fill up my Cilo, I noticed the valve that I put my fuel into had fallen into the diesel tank as there’s nowhere else it could have gone and left just a hole. should I be concerned? Will it damage the car?
Feb 11, 2025 at 6:54 PM
  • 55,649 POSTS
I would use a flashlight and look down inside the fuel filler neck, chances are you will be okay because the filler valve will sit in the bottom of the tank or get stuck in the filler neck itself. Please upload pictures or videos in your response of any problems so we can see what to help you with.
Feb 12, 2025 at 2:10 AM
