I hear a noise and my pedal jumps
178,000 MILES • 3.4L • V6 • 4WD • AUTOMATIC
GR52VEY
  • 9 POSTS
When I stop and step on my brakes I hear a noise and my pedal jumps, like it does not want me to step on it to stop. I got the left brake sensor and bearing changed. Can that be the problem? Please Help.
May 2, 2018 at 1:54 PM
CARADIODOC
  • 34,415 POSTS
A brake rotor is warped or there is some debris stuck behind it. Both are very common problems that should be easy for your mechanic to diagnose and solve.
Apr 12, 2021 at 11:00 AM
GR52VEY
  • 9 POSTS
There is no lights showing on the dash and thank you. So I will ask my mechanic to check.
  • 55,802 POSTS
When the brake pedal jumps do you here a noise like a large clock winding? This would be the ABS kicking in due to a bad sensor which can be caused by a bearing hub going out.
Cheers, Ken
GR52VEY
  • 9 POSTS
Ken, I think I found out what it is. The mechanics failed to tell me or his work from before when they change the bearing and sensor that my wire was burnt. I have to take back to them I think this is the problem.
GR52VEY
  • 9 POSTS
And I think this was the problem from the beginning Ken and I paid for a whole new bearing and sensor because it said this.
  • 55,802 POSTS
Yep, you found the problem, nice work. Use 2CarPros anytime, we are here to help. Please tell a friend.
Cheers, Ken
