I need to pull out the frame
180,000 MILES • 2WD • AUTOMATIC
ASHLEY9269
my car was wrecked in a ditch and i need to pull my front frame out a little bit so i can replace the radiator. How can i pull the frame out some?
May 15, 2016 at 3:59 PM
HMAC300
  • 48,601 POSTS
that should only be left to professionals as it takes hydraulic jacks to pull frames out. If you try to do it your jacks will will not be strong enough to hold it before it breaks something.
May 15, 2016 at 11:39 PM
