My engine does no start
75,000 MILES • 1.5L • 4 CYL • 2WD • MANUAL
COPAH
Hello everyone, I need help please. when I put the key in the start position I have a lot of fault on the dashboard, in branch the diagnostic case the mechanic to note that the engine calculator is not found. he made a shunt on a relay and the case could see the calculator which allowed him to erase the defects. after removing the shunt we tried to start but without success, the starter does not even turn (it is good condition). when he puts the shunt we get to start but the engine speed is catastrophic and the vehicle has no power and we can not even accelerate. The relays and fuses have been controlled and are all okay. the defects come back and not moment one that indicates error engine calculator. Help me please.
Jan 27, 2018 at 3:59 PM
Good morning.
Before he erased the fault codes, did he record them? We need those codes to narrow the area of failure.
Any information would be helpful to us to help get the information.
Jan 27, 2018 at 10:44 PM
COPAH
Hello, here are the codes that have been erased:
P0606 and p0110,
The reference of the engine calculator is the following: 1860A800.
Thank you again for your help.
Jan 29, 2018 at 3:08 AM
Okay, the 606 is the key. It is a code for the PCM processor has failed internally.
You need a PCM to start.
Jan 29, 2018 at 3:11 AM
COPAH
Okay, but do not you have a way to confirm this flaw please? it is that this piece (PCM) costs excessively expensive in my country.
Jan 29, 2018 at 3:43 AM
COPAH
Or if you have one where I can buy this piece?
Jan 29, 2018 at 3:51 AM
The code refers to this specifically and states to replace PCM. There is no test other than sending it somewhere to be tested as it takes special equipment to test it.
You can take the numbers off it and go online and search for a replacement. after you find one it will have to programmed to your vehicle.
Jan 29, 2018 at 3:58 AM
