The radio, mirrors, dome lights, and door locks are all inop.
Jul 27, 2014 at 7:21 PM
HMAC300
✓Experienced Mechanic
check fuses first windows and door locks are underhood then get it scanned for codes may be the tpiim module
Jul 27, 2014 at 11:47 PM
AJISALW
MEMBER
I checked all fuses none are blown and dey not under da hood dey on da inside
Jul 27, 2014 at 11:53 PM
HMAC300
check items in pics fuse 19 runs radio, powr mirror etc. check circuit breaker 1 and 2 for locks and door and ground under drivers seat as it's for everything except radio and lights. fuse 19 is also for lights and have scanned for a body module problem.
Images (Click to enlarge)
Jul 28, 2014 at 12:16 AM
AJISALW
MEMBER
I just checked under the hood it don't even go by numbers its letters and da 19 fuses on da side of the driver side dash is dome lights
Jul 28, 2014 at 12:25 AM
HMAC300
have a pro look into this as I think it's something he can find for you the circuit breakers are in the dash panel fuse box. I think you have a broken wire between door and jamb is causeing the problem unless it's a switch
