Can I ask if the security light is flashing while you are cranking the car over? if so this will be the problem. Let me know what happens please, Ken
Feb 14, 2026 at 12:52 AM
DENNIS HEN
MEMBER
Feb 14, 2026 at 5:27 AM
DENNIS HEN
MEMBER
Security light does flash while cranking
Feb 14, 2026 at 5:29 AM
✓Experienced Mechanic
Yep, that is the security system enabled. The ECM will need to be programmed. You can have a mobile locksmith come out to do the job/program the ignition key it should cost about $250.00 of call he website above to see what they can do.
