Does the cruise control operate? If it works properly then I suspect the fuse for the IP is the issue.
However, if the cruise does not work then we have another issue.
Let's start with this and I attached the fuse info below which is in the underhood fuse block.
Let us know what you find with this info and we can go from there. Thanks
Images (Click to enlarge)
May 8, 2021 at 2:03 AM
