clutch pedal is going to the floor no pressure at all
2006 FORD F-150
200,456 MILES • 4.2L • 6 CYL • 2WD • MANUAL
JEROME PHILLIPS
MEMBER
1 POST
Upon trying to start, the engine is engaged the clutch and went to the floor no pressure at all. It feels like it is not attached.
Feb 4, 2017 at 12:43 AM
HMAC300
✓Experienced Mechanic
check hydraulic clutch fluid first if empty check for a leak. then have an assistant push clutch in while watching slave cylinder at clutch. if it goes in all the way then it is a clutch problem. if master to clutch hydraulic was empty fix the leak then bleed the system then get back to us.
Feb 4, 2017 at 2:39 AM
