Wobbles, shakes
201,128 MILES • V6 • 2WD • AUTOMATIC
SHEY PALS
My car will start to wobble or shake when I’m in drive, park, neutral. I hooked my obd2 reader up to it and it says no dtc data on computer? I would also like to know what that means? please and thanks !
Aug 7, 2019 at 9:59 AM
STEVE W.
  • 15,387 POSTS
Welcome to 2CarPros. So with the engine running it shakes, does it start doing this as soon as it's started or does it need to warm up a bit first? When you first turn on the key does the CEL come on and then turn off when you start the engine? Does it blink when the shaking is going on? What code reader do you have? Have you tried it on other vehicles just to be sure it works? No DTC usually means no codes.
Aug 8, 2019 at 7:07 AM
