My car will not turn over
177,000 MILES • V8 • AUTOMATIC
WALLY740
I had my starter replaced it started fine for the first three times, then I went to start it and then it would not crank over. however, I did press the lock button on the key but the car did not lock because battery was drained on the key fob. I put a new battery in it and it still does not work and my car will still not start.
Nov 21, 2017 at 2:24 PM
F4I_GUY
  • 3,302 POSTS
Okay let's try to diagnose the start issue first. The key problem may simply be it needs to be relearned to the vehicle because the battery was disconnected.
Have you rechecked all the repairs you made? Have the connections accidentally loosened? How about the battery? Have you done any voltage tests on the battery? Below will be some quick links on your battery and starter system that will help you out.
https://www.2carpros.com/articles/how-a-starter-and-solenoid-works
The last link will show you how to load test the battery. Perform this test to eliminate the battery as the culprit. If the battery passes you know the issue is with the starter or starter circuit itself.
Nov 22, 2017 at 2:43 AM
