My car won't stay idle end misfire check code has po300
2003 TOYOTA TACOMA
22,670 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
MARIEBEN55
I replace the fuel pump end tune up replace all coil check the firering order start wen I step the gas pedal hessetate end stumble end died end I remove the converter engine light on po300 code
May 19, 2014 at 2:24 PM
HMAC300
  • 48,601 POSTS
that 's a misfire code recheck yoru work and make sure your firing order is correct. after you have rechecked your work and are still getting the code have a pro diagnose this as these are extrememly hard to find the cause
May 19, 2014 at 11:57 PM
