Will not stay cranked and running
1997 CHRYSLER LHS
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
ANEDA
I had to put a fuel pump on my car and I bought a used one. It'll crank but it won't stay cranked and running. it's something to do with the security system I think. what do you think or what should I try or do?
Mar 29, 2019 at 8:51 AM
JOETECHPRO
  • CAR REPAIR CONTRIBUTOR
  • 705 POSTS
Hey ANEDA,
So you have replaced the fuel pump but the vehicle still has the same fault?
Did you check fuel pressure before?
Can you hear the pump running with ignition on?
Please read through the guide below, may give you some helpful information:
If you think it may be s security system issue please read the guide below:
https://www.2carpros.com/articles/how-to-reset-a-security-system
Hope that helps.
Any further questions don't hesitate to ask we can run you through any further checks you need to get your vehicle going again.
Regards, Joe
Mar 29, 2019 at 5:02 PM
