My Car cranks but will not start
133,264 MILES • 6 CYL • 4WD • AUTOMATIC
CYMYEON
  • 8 POSTS
I recently changed the fiber in the gearbox on my car. After that, I mounted the gearbox, but the car will not start. It will crank, but will not start for two days now. Have scanned to find out the problem, it shows "security". The engine cranks well, showing no error code, but just will not start. What do I need to do?
Thank you,
Cymyeon
Sep 11, 2018 at 1:51 AM
  • 110,251 POSTS
There is a chance you may have to return the vehicle to the dealer for key registration reset. Try this first. If it does not help, let me know.
____________________-
Note: If you have anything on the key ring that can cause interference with the unit, remove it. Items such as small automated payment cards can interfere with the system.
a. Leave the ignition switch in "on" position for approximately five seconds.
b. Turn ignition switch to "off" or "lock" position and wait approximately five seconds.
c. Repeat step 1 and 2.
d. Start the engine while holding the device (which may have caused the interference) separate from the registered NATS key. If the no start condition re-occurs, NISSAN/INFINITI recommends placing the registered IVIS (NATS) key on a separate key ring to avoid interference from other devices. If there is no device to cause interference, reprogram the key and NATS.
_____________________________
Let me know if this helps.
Sep 14, 2018 at 12:51 PM
STEVE W.
  • 15,423 POSTS
If the security light is on the system has disabled the engine controls. As a first step you can disconnect the battery at both cables. Now touch the disconnected cables together to drain off any stored power. Next wait five minutes and reconnect the battery. Now use the key to lock and unlock the drivers door. Now try it and see if it will start. If not then try a different key as well.
Sep 14, 2018 at 1:09 PM
CYMYEON
  • 8 POSTS
Thank you very much Joe and all professionals on 2CarPros.com the advice were very useful. I tried them and it worked like magic. Now my is car rolling like a bird on the tarmac.
Many thanks,
Cymyeon
Sep 23, 2018 at 4:55 PM
  • 110,251 POSTS
That is good news. Glad it helped.
Take care and let us know if you have questions in the future.
Sep 24, 2018 at 10:01 AM
CYMYEON
  • 8 POSTS
Sure, the car moved well the first two days. But now, I drive only using 2w. If I use the 4WD, AUTO, or 4H or 4LO, the car does not select beyond two forward gear. Now I cannot even use the 4WD in the mud or sand. If I do, the car does not select more than first and second forward gears. And it keeps revving. What do I need to do?
Oct 3, 2018 at 7:39 PM
CYMYEON
  • 8 POSTS
As at now, I have disconnected the auxiliary gear. If the auxiliary I connected, it does not select more than first and second forward gears.
Kindly help out.
Thank you,
Cymyeon
Oct 3, 2018 at 8:37 PM
  • 110,251 POSTS
Hi again. I am not sure I totally understand what is happening and what you have done. The 4wd options are not working? Also, when you say you disconnected the auxiliary gear, what are you referring to?
Oct 4, 2018 at 9:22 AM
CYMYEON
  • 8 POSTS
Hi Joe, thank you for stepping in. Yes, the 4wd options are not working.
Secondly, I had to disconnect the auxiliary propeller, so that I can move the car as it could not select gears on movement.
Kindly help out.
Thank you,
Cymyeon.
Oct 5, 2018 at 3:18 AM
  • 110,251 POSTS
When you shift into a gear, does the indicator show you have changed gears? Also, check to make sure the connectors to the transfer case actuator motor are clean and tight. I attached a picture of their location.
Note: Prior to removing the drive shaft (propeller), would the car move in neutral?
Oct 6, 2018 at 1:06 PM
CYMYEON
  • 8 POSTS
Hi Joe, thank you. Before removing the drive shift, it was not moving in neutral.
2). When I shift into gear, the indicator shows that I have changed gears.
3). I will try your advice.
4). I will revert back to you on results.
Thanks you once again.
Cymyeon
Oct 7, 2018 at 3:53 PM
  • 110,251 POSTS
Make sure the shifter linkage is attached at the transmission, too.
Oct 8, 2018 at 9:24 AM
CYMYEON
  • 8 POSTS
Hi Joe, thank you for your expert advice. You are the best! I tried it all, it worked like magic. The car is crooning like a child. I really, really appreciate your experience and expertise.
Thank you once again.
Best Regards,
Cymyeon
Oct 8, 2018 at 2:26 PM
  • 110,251 POSTS
Wonderful. I am glad it helped. Feel free to come back anytime you need help.
Oct 9, 2018 at 10:11 AM
CYMYEON
  • 8 POSTS
Hi Joe, I am back again. This time, the car engine overheat. The technician replaced the top gasket. Coupled it back, the car would crank, but won't start. The pressure is okay, fuel supply too, okay. He reset the timing chain, the electrician had it checked, But no power to the spark plugs. All spark plugs new. Why do I need to do?
Cymyeon
Jul 4, 2019 at 6:48 AM
  • 110,251 POSTS
Welcome back:
No start again? Since the work was done, make sure the crankshaft position sensor wasn't left disconnected or the wiring to it was damaged.
See picture 1
Let me know. I have a feeling something was left disconnected.
Jul 4, 2019 at 11:32 AM
