My car will not start
102,865 MILES • 4.6L • V8 • FWD • AUTOMATIC
TOROKCO POLK
Car was cranking with no dash light now will not start or nothing.
Sep 22, 2017 at 9:31 AM
STEVE W.
  • 15,423 POSTS
Okay, so you put the key in, turn it and get nothing? No dash lights no head lights? Just a dead car?
First thing I would check are the battery and battery connections. GM side terminal connections are known for corroding inside the rubber insulation and causing a no power situation. Check on both ends as a loose/poor ground or positive feed will act the same way.
Most parts stores will test the battery for free. You need battery voltage and cranking amps from the test.
Sep 22, 2017 at 3:05 PM
