my car wont start no fault codes
100,000 MILES • 2.0L • MANUAL
SHEZ12
My car wont start, is showing no faults in diagnostics test. I can the ignition coil as recommended as been told there is no spark. But still nothing, its turning over but still no spark. Can you help please?
Oct 3, 2016 at 3:37 AM
SATURNTECH9
  • 30,868 POSTS
Please bear with me we no repair information on that car we only have repair information on USA sold cars only.Do you have a code reader that can show live engine data line engine rpm?Also have you checked the engine crankshaft position sensor with a multi meter?
Oct 3, 2016 at 5:29 AM
SHEZ12
I do not have anything to read with, a mechanic I bumped into by chance looked it over and thought it just the ignition coil. I am clueless about cars. How would I check the crankshaft sensor?
Oct 3, 2016 at 11:58 PM
SATURNTECH9
  • 30,868 POSTS
With a multi meter reading ohms there usually like 800-1200 ohms usually when the test bad they will read no resistance as a open circuit.
Oct 5, 2016 at 1:11 AM
