It was in the evening and I had to run to the store I had just gotten home, it was a very hot day, there was no problems before I had reached home. when i tried to start the car again it wouldn't start, it just had a rapid sound as if the battery needed a charge. I brought a new battery an starter , and brought a fuel pump relay. I later realize that the fuel pump was working because I could hear it priming when I turn the key. I then learned from YouTube about the pgm-fi main relay in hot weather and how it played a role in a lot of Acura and Honda problems. The fuel injector, and the eECU are not communicating either, just a guest. Hope you will help. Thanks !
Feb 5, 2020 at 5:55 PM
