Car wont start
180,000 MILES • 3.8L • 6 CYL • AUTOMATIC
MWILLIAMS2K15
  • 6 POSTS
Yesterday I changed my coolant bypass elbows. Before I started I disconnected the negative terminal on my battery. After I got done I reconnected the negative and now my car will not start. I tried to remove my key and it would not come out. It will not shift out of park. My security light is not on. Checked fuses and they are fine. My gas needle does not move when car in on position. My radio works, but no lights on inside. Also when the car is in on position I hear like a hissing noise and one click, but when I try to crank it, nothing. Any ideas on what is going on?
Jun 6, 2016 at 1:21 AM
HMAC300
  • 48,601 POSTS
try resetting security system due to battery disconnect if no owners manual look online for your car on how to do it.
Jun 6, 2016 at 2:40 AM
MWILLIAMS2K15
  • 6 POSTS
Okay, I will try that, but another thing, my steering wheel wont lock either.
Jun 6, 2016 at 3:15 AM
  • 55,743 POSTS
Hey,
Can you turn the headlight on to see if the battery if good? it sounds like it is dead.
Here is a guide to test it.
https://www.2carpros.com/articles/how-to-check-a-car-battery
Let me know what you find
Jun 6, 2016 at 4:16 AM
MWILLIAMS2K15
  • 6 POSTS
My headlights come on. It seems like nothing is registering in my car. Normally when I turn my key to the ON position it will give me a fuel range to empty but when i do it now it just gives me dashes. Its like that for all of the features on my dash. Could it be some with the computer in my car.
Jun 10, 2016 at 11:28 AM
HMAC300
  • 48,601 POSTS
it may be a weak battery doing this, check for condition including load test. most places do for free
Jun 10, 2016 at 10:50 PM
