My car will cut off while driving.
119,000 MILES
JILLYPOO
while driving my car will cut off the cruise control green key light comes on. When this first started it would start back up within a couple seconds. Now I have to put it in N and start it while I'm coasting. I was told it could be the starter switch and it was recalled and replaced already. I have 1 key on my key ring so it's not to heavy. Hope you can help me before it won't start at all and leaves me stranded somewhere. It's very scarey! Thanks
Jul 2, 2013 at 9:42 AM
KHLOW2008
  • 41,812 POSTS
The green key is not the cruise control. It is the security warning indicator and if other dash indicators lights are not turning on when engine stalled, the problem should be caused by the ignition switch. Having the switch rerplaced previously does not mean it would not go bad again.
Jul 2, 2013 at 11:27 PM
JILLYPOO
Thank you so much. I will get that replaced and hopefully it will take care of this problem!!!! Thanks again!
Jul 4, 2013 at 12:34 AM
KHLOW2008
  • 41,812 POSTS
You're welcome.
Have a nice day.
Jul 4, 2013 at 4:06 AM
HONDATECH1983
  • 109 POSTS
Another problem could also be the Immobilizer. If the immobilizer is not recognizing the proper signal from the key the PCM will not allow the vehicle to run.
Nov 20, 2013 at 9:13 AM
