my car tries to start itself
189,783 MILES
JUSTINB1983
I heard a continuious clicking from my driveway upon inspection i noticed my car was trying to start itself it was going clickclickclickclickclik i unpluged the batterie and it stoped but as doon as i hok up the batterie it would start doing again.i have replaced the starter and ignition swith and it still does it
Jul 7, 2013 at 12:36 PM
HMAC300
  • 48,601 POSTS
find the relay that is clicking underhood and get back so we know what system it is they are marked on underside of fuse top
Jul 8, 2013 at 12:07 AM
JUSTINB1983
At first the clicking was by the fuse bix now it sounds like it coming fron underneath the car near the starter
Jul 8, 2013 at 1:18 AM
HMAC300
  • 48,601 POSTS
then something is engaging the solenoid on the starter you'll either have to replace the starter or find out what is causing it to do that like something hitting the start pole of solenoid
Jul 8, 2013 at 3:37 AM
JUSTINS1983
I have already replaced he starter and it still does it someone said either the crank relay ,the netural possition sensor or cam shaft possition sensor
Jul 8, 2013 at 4:03 AM
HMAC300
  • 48,601 POSTS
it would help if y ou give us all the details instead of endless emails like you are doing. it may be the starter relay which is in the underhood fuse box. but if that doesn't cure it then you have amore serious problem like a shorted wires or something similar
Jul 8, 2013 at 4:55 AM
