MY car surges when driving when i
218,000 MILES
WAYNE321
I have a 2002 chevy cavalier 2.2L/fuel injection SL SPORT COUPE that's been surging while driving at a constant speed once I give it gas as to go faster or pass someone I have aLL the power with NO surging . LIKE I said before at one constant speed it surges until i go faster. WHAT COULD CAUSE THIS TO HAPPEN ?
Jul 17, 2013 at 2:15 AM
  • 110,251 POSTS
Check for engine vacuum leaks, check fuel pressure regulator, if the check engine light is on, have the computer scanned to identify trouble codes. Most parts stores will do it for free.
Jul 17, 2013 at 6:18 AM
WAYNE321
yes im replying to your answer my engine light has not come on if it did I would of gone to a parts store tohave engine scanned for trouble codes which I have done in the past.i will check for vacuum leaks check fuel pressure regulator IF it is the fuel pressure regulator where is it located and howMUCH for the part. ALSO one more thing if it is neither one of these problems what other problems could there be ? I just put a new catalyst converter on a few months ago so I don't think it is that. I thinking maybe fuel filter or plugs maybe even a fuel injector .what do you think ? please reply back thank you . wayne
Jul 17, 2013 at 7:49 AM
  • 110,251 POSTS
The regulator is on the fuel rail. As far as plugs, that wouldn't cause this type of problem but a fuel filter could.
Jul 17, 2013 at 11:05 AM
WAYNE321
OK thanks for your help I will check these issues out and hopefully get this resolved. THANK YOU VERY MUCH ! Wayne321
Jul 17, 2013 at 12:33 PM
  • 110,251 POSTS
Wayne:
I hope I helped. Let me know what you find.
Jul 18, 2013 at 8:21 AM
WAYNE321
I will THANKS AGAIN Wayne321
Jul 18, 2013 at 2:27 PM
