Loud hissing noise
230,000 MILES • 3.2L • 6 CYL • TURBO • 2WD • AUTOMATIC
CHARITY78HOPE
After my friend did a minor tune up, new spark plugs,ignition coils and oil. changed because he got a misfire code. First the check engine light just went off than drove maybe forty miles and check engine light came back on flashing especially during acceleration. now upon start it screams like a ready teapot with acceleration. the screaming subsides or goes completely away. The engine runs strong no skips nothing but this is very annoying. Where do we look to eliminate this noise? It is so loud in the engine compartment at an idle it is hard to isolate where it is coming from.
Jul 1, 2017 at 1:57 AM
HMAC300
  • 48,601 POSTS
check to make sure all duct work from air cleaner to engine is on correctly and no holes in it. then check for a vacuum line off/broken or cracked and leaking then check for some loose on intake manifold. scan for codes to see if it will pick up anything code wise as well.
Jul 1, 2017 at 2:43 AM
