Why does my car smell like rotten eggs?
145,000 MILES • V6 • 4WD • AUTOMATIC
AUSTIN1997
The inside of my car smelled like rotten eggs one day when i went out to it. I have cleaned it out thinking maybe it was something in there the smells still is there after couple of days. I have smelled the muffler when the car was on and it smells like normal exhaust fumes so i would not think it's the catalytic convertor. I was not sure if there was an answer that could be causing this foul smell. [The car is a 2011 not 2012]
May 6, 2021 at 8:12 AM
The number one reason for this is the catalytic converter. So I would suggest testing the converter as smelling the exhaust won't be sufficient. Here is a guide that will help with this:
https://youtu.be/kNXh1Lphzr4
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
The other reasons are fuel issues or old transmission fluid. I would suggest checking the fuel pressure next and then check the fluid to make sure it is not old.
However, I suspect you have a failed converter and it will need to be replaced. Let us know what you find with this material. Thanks
May 7, 2021 at 1:15 PM
