When starting to accelerate there is a noise like something is being rolled up in the engine compartment
185,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
JHS DISENO
My car has a problem when starting to roll begins make a noise as if rolls a piece with another in the engine part. the transmission is correct in my opinion because the changes makes normal and in time. I have changed the bearings, tie rod, the CV axle on both sides and still making the same noise. also, change rotors and brakes. do not know what is the problem.
Dec 31, 2017 at 3:26 AM
  • 31,937 POSTS
If the noise is constant with road speed you need to be re checking all drive line components including wheel bearings and anything that is turning. also, check rear as well, noises can travel, you may be chasing a rear noise that you think is in the front.
Dec 31, 2017 at 12:48 PM
