My car just shut off after driving one kilometer
300,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
MIKELARRY
I need help please.
I started the car drove of about one kilometer and the engine just cut off. I cranked the car theirs enough power to crank and the fuel pump is on with the ignition but no start. I have not checked for spark yet but my fan is direct on the ignition coil, so when I switch on the ignition the fan does not go on as it use to. So can it be the ignition coil cause if i unplug the fan from the coil and put it direct to the battery? The fan works but as soon as I place it back to the coils positive it does not go on with the ignition. So can it be the coil?
Oct 12, 2018 at 6:42 PM
  • 55,628 POSTS
It sounds like with the fan connected it overloads the coil circuits which then overheat. I would reconnect the fan the way it should be here is a wiring diagram to help you rewire the fan motor.
Cheers, Ken
Oct 15, 2018 at 4:55 AM
