My car is smoking and jerking slightly
263,890 MILES • 2.2L • 4 CYL • AUTOMATIC
ASHLEYBULLARD1128
I randomly checked my oil and it was low. So I went and bought some. I could not remember which weight to get, so I got 10-40 (which when I got home I found out I usually get 10-30). Well I put the oil in and then checked the stick and it was the right amount. The next day I drove it, the gas pedal would not budge when I got up to forty two mph and when it finally started working, my car started smoking from the exhaust pipe and kind of jerking and the smoke was kind of dark grey and smelled bad. I checked the oil and it was way over the limit. So now every time I drive, the gas pedal acts funny and then my car starts having greyish smoke almost white like coming out of it. This last time driving it, my engine was quieter than using and my car was not reacting to the gas pedal being pushed. I pulled over checked the oil, it was normal and then crunk it up and it drove normal. I have only been driving a week like this, since I have no other car. Could I just change the oil and it would be fine again or is it something else?
Dec 22, 2016 at 9:55 AM
JOHNNY G.JR
  • 320 POSTS
Pull spark plugs and inspect them. are they sooty black?
Dec 22, 2016 at 11:44 AM
ASHLEYBULLARD1128
Where would my plugs be located? I know a little bit about car, but not too much.
Dec 22, 2016 at 2:03 PM
  • 55,770 POSTS
Hey ASHLEY,
I would first change the oil and the spark plugs to make sure they are good first,
Here are two guides that will help you get the problem fixed.
https://www.2carpros.com/articles/how-to-change-engine-oil-and-filter
and
https://www.2carpros.com/articles/how-to-change-spark-plugs
Please let us know what you find so it will help others.
Best, Ken
Dec 27, 2016 at 12:39 AM
ASHLEYBULLARD1128
I got my oil, oil filter and air filter changed the other day and it hasn't smoked. But my gas pedal still resists a little at 40 mph and up. Also my ABS keeps coming on and staying on. I forgot to mention that in my post. It will stay on and sometimes it won't.
Dec 27, 2016 at 7:30 AM
  • 55,770 POSTS
Hey ASHLEY,
This sounds like it could be a catalytic converter that is starting to plug up.
here is a guide that will help you.
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Best, Ken
Dec 28, 2016 at 1:45 AM
