When stopping the car the engine shuts off
99,850 MILES • 1.9L • 4 CYL • 2WD • AUTOMATIC
PANABY MUTENA
My car is not drawing enough fuel whenever i stop at a light and if i fully depress the accelerator it switches off. please assist me., is it the fuel pressure regulator, fuel pump, fuel filter or fuel pump relay? My engine check light is also on.
Mar 19, 2019 at 6:08 AM
JOETECHPRO
  • 705 POSTS
Hey PANABY MUTENA,
Can you begin by scanning the codes?
Let us know what codes you have stored and we can then narrow down the potential causes.
Regards, Joe
Mar 20, 2019 at 5:28 AM
  • 55,628 POSTS
Here is a guide to help you get started:
To me it sounds like the car is going into limp mode due to a dirty throttle bore which causes the computer to lose correlation with the throttle body causing the limp mode. Here is a guide to help fix the problem:
https://www.2carpros.com/articles/reduced-power-limp-mode
Mar 20, 2019 at 10:21 AM
PANABY MUTENA
I've had it diagnised and the codes are P0171 (Fuel System Too Lean) now from here what should i do next. Your advice is greatly appreciated...
Mar 22, 2019 at 7:16 AM
JOETECHPRO
  • 705 POSTS
Hey PANABY MUTENA,
So having a fuel system too lean code can point to a few things.
If you have not had the fuel filter replaced then at the mileage of your vehicle i would advise this would be a required service item anyway so a good place to start.
Also checking for air/vacuum leaks is free and can highlight an issue quickly.
A vacuum leak would cause the issues you are having.
Please let me know if you have any further questions regarding either of these checks.
Regards, Joe
Mar 23, 2019 at 3:30 AM
PANABY MUTENA
Good Day.
So I have taken your advice and i checked the MAF Sensor to my surprise it was very dirty. now i cleaned it and it's now taking off smoothly from any point, but now when i accelerate to gain speed it is jerking whenever the rev counter reaches 3.5 rpm and drops speed same time. what else should i check? there are also two Oxygen Sensors that i haven't checked could it be them? The engine check light is still on please assist me further..
Thanks in advance.
Apr 7, 2019 at 5:51 AM
JOETECHPRO
  • 705 POSTS
Hey Panaby Mutena,
Have you checked for vacuum leaks?
As in the guide i mentioned before.
Did you clean the MAF or the throttle body?
If cleaning the MAF has improved the issue try unplugging the MAF and driving, does that fix the issue?
Regards, Joe
Apr 7, 2019 at 8:52 AM
PANABY MUTENA
Good day Joe,
Okay let me try it then i'll also check the throttle, but now i can't locate the throttle position clearly.
May 7, 2019 at 9:31 PM
  • 55,628 POSTS
Here is a guide to help you with diagrams below to help walk you through the steps:
May 8, 2019 at 4:24 AM
