My car's heater is not blowing out warm air
2012 CHRYSLER
100,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
STEPHANIE MARLEY
The car is heating up but when I turn on the heater it just blows out cold air.
Oct 13, 2016 at 6:50 AM
WRENCHTECH
  • 20,760 POSTS
With the engine at full operating temperature, locate the two heater hoses where they go into the firewall and feel them to see if they are both hot to the touch. If they are both hot, the heat in that vehicle is controlled by a blend door that regulates heated air flow. it is operated by an electric motor/actuator. The problem can be that the actuator is stripped or inoperative or the door itself could be damaged. This is what needs to be determined by examining the actuator and see if it is responding to heat change commands or not.
Oct 13, 2016 at 7:35 AM
