My car is leaking oil and coolant
APAYNE8
  • 2002 VOLKSWAGEN PASSAT
  • 179,000 MILES
What do think needs to be replaced on my passat? Its leaking oil and coolant, not at a fast rate, but I am still losing oil and coolant. Im not sure what to do about this problem.
Thanks!
Monday, August 5th, 2013 AT 9:04 AM
EXOVCDS
  • 1,883 POSTS
Follow the leaks the their source. Then let us know where the leaks are coming from.
Once we know where the leaks are coming from, we can tell you how to fix the leaks.
Thomas
Monday, August 5th, 2013 AT 9:44 AM
EXOVCDS
  • 1,883 POSTS
There are common leaks for both oil and coolant on 1.8T and V6 engines. If you tell us what size engine you have, we might be able to help.
Thomas
Monday, August 5th, 2013 AT 2:04 PM
  • 31,937 POSTS
You will need to pressure test the cooling system and was and re inspect for fresh oil leaks, this should be done by a mechanic so as not to miss any leaks and get the correct identification of problem parts.
Saturday, August 10th, 2013 AT 12:22 AM
