my car is accelerating on its own.
74,000 MILES • RWD • AUTOMATIC
GENE81
  • 5 POSTS
I have a 1981 Monte Carlo, 350 motor, edelbrock intake, Holley carb, I don't know the exact specs on them parts( not a car guy, just a drywall guy), today I extracted a broken bolt from carburetor that holds air filter in place, using an easy out, I think I might have screwed something up in the process, now it idles really high, my tach is broke, so I don't know how high, and when I put it in drive, it accelerates on its own to about 40 mph(before I applied brakes anyway) when its in reverse it gets quieter but still accels on its own, I'm so confused, what's wrong, how can I fix it? Please and thanks.
Feb 17, 2015 at 12:01 PM
DR LOOT
  • 2,311 POSTS
I would like to see a photo of the extraction job on the carburetor, then maybe I can help you.
Feb 17, 2015 at 1:09 PM
GENE81
  • 5 POSTS
Sorry its dark, was running late for work.
Feb 17, 2015 at 9:13 PM
GENE81
  • 5 POSTS
That's carb/airfilter with new bolt.
Feb 17, 2015 at 9:15 PM
GENE81
  • 5 POSTS
Easy out/w broken bolt
Feb 17, 2015 at 9:17 PM
DR LOOT
  • 2,311 POSTS
the extraction looked pretty clean, did you vacuum the shavings out of the carburetor? are the butterflies at the bottom of the carburetor all the way close? it looks like a 600 CFM Holley? do you know how to adjust the idle on that carburetor? since you were working around the carburetor and the engine compartment make sure all the vacuum lines are in the right position and you didn't knock one off accidentally, check especially the brake booster vacuum line make sure that on and insecure.
Feb 18, 2015 at 12:23 AM
GENE81
  • 5 POSTS
Thanks alot, I'll check all that after work, if it warms up a little
Feb 18, 2015 at 1:19 AM
DR LOOT
  • 2,311 POSTS
Roger that
Feb 18, 2015 at 12:18 PM
