My car has an intermittant miss
150,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
MICHAEL ROGERS
The frequently will start to drop one cylinder every half second at any RPM, throttle, gear, hot or cold, wet or dry etc. It can usually be cured by turning the engine off for 15 seconds then back on whereupon it runs great! Does the PCM poll the sensors?
Jul 19, 2019 at 8:39 AM
SCGRANTURISMO
  • 4,897 POSTS
Usually the Crankshaft Position Sensor (CKP) is the sensor the Power-train Control Module (PCM) or "computer" uses for it's misfire monitor. It can determine misfires from the CKP because every time there is a misfire, the crankshaft will slow down and the PCM is able to track this with great precision, even being able to determine which cylinder is misfiring. I can send you the Ford factory pinpoint test for your vehicle's misfire monitor, Pinpoint Test HD, but it requires the use of a scan tool capable of accessing the vehicle's PID values, and a special tool, called a breakout box. If you would like us to send you these tests, please get back to us and let us know, otherwise, here is a link for you to go to.
Please go through this guide and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
Jul 19, 2019 at 12:34 PM
MICHAEL ROGERS
Thanks for your input!
I've already done a compression test, compared the plug colors (same) lite tan/gray. Replaced the ht wires, the engine winds cleanly to 7,000 when it's not misfiring, again: it doesn't miss regularly on one cylinder like it would with a bad injector, it drops one cylinder at the same time spacing no matter what rpm!: +/- .5 seconds, i'll have to see if my Allstate obd2 will read that code and need to learn about the breakout box. can i find it on eBay? I guess it's for the obd2 plug. This is the first computer controlled vehicle i've had, i've raced lotus ford, have a Lotus Europa TC special that i've maintained and built, i have a Cosworth mk-9 formula 2 engine in my 1963 Capri GT (with a milder cam) and this cheap car is more complex than any! Not to mention harder to work on! i've been to a dealer twice in my long life and it's for this car which i love! They knew nothing! Please send me the test information and where i can get the breakout box!
Thanks!
Jul 19, 2019 at 3:31 PM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
That's awesome. I have a supercharged 97 Ford Mustang GT that I built from the pistons up that is producing around 400 rwhp, and I haven't touched the restrictive first generation heads on my engine, and haven't touched the cams at all yet. Look if you know cars, then you know modern cars. All the sensors are doing is taking something that older cars did mechanically, and is converting it to electricity. Electricity is the language that the computer(fuel injection and ignition timing input/output device) understands. All cars are the same, basically, and it breaks down like this, Mass Air Flow Sensor (MAF) reads the amount of air the engine is ingesting, Intake Air Temperature Sensor (IAT) reads the temperature of the air, Throttle Position Sensor (TPS) reads where the throttle is idle - Wide Open Throttle (WOT), Engine Coolant Temperature Sensor(ECT) reads coolant temperature, and Heated Oxygen Sensors(O2 Sensor) which reads the Oxygen in the exhaust for the Air:Fuel ratio(14.7:1). There are a few others, but they all deal with emissions and are not for engine performance. There it is. Not so difficult after all. Remember, the sensors take mechanical and turn it into electricity. The breakout box you can purchase on Ebay, they cost around $300.00. Basically it is a box with the 104 holes on the face that you plug inline in between the Power-train Control Module (PCM) or "computer" connector and the PCM. Each hole substitutes for that pin on the connector and you can use your multi-meter to run tests without messing up the pins on the PCM or the Connector or wiring harness. Anyway I will get those pinpoint tests to you in a few.
Thanks,
Alex
2CarPros
Jul 19, 2019 at 7:44 PM
