I have a problem where theres a cylinder misfire in the 3rd cylinder, I had someone look at it and they told my to pull out this sensor but when I took it off I found out it was a cam shaft sensor. It runs and drives but stall everytime I press the brake
SPONSORED LINKS
Monday, January 18th, 2010 AT 8:03 PM
BMRFIXIT
MECHANIC
Clean throttle and check IAC valve
what do you have for codes?
Monday, January 18th, 2010 AT 9:18 PM
MECHANIC
Check the spark plug, compression and injector for #3 cylinder.
And also check the power brake booster if it's leaking.
