1998 Ford Escort ENGINE MISSFIRE ACELERATING
CHOPPLEY101
  • 1998 FORD ESCORT
Engine Performance problem
1998 Ford Escort 4 cyl Two Wheel Drive Manual 87.000 miles
Hi I have a ford escort 1.6 Finesse, when I rev the engine it misfires as I first press the throttle then goes okay, when driving and reving it feels like a misfire, it only happens when I put my foot down on the accelerator.
Sunday, May 23rd, 2010 AT 5:23 PM
  • 109,885 POSTS
Has the check engine light come on? When was your last tune up?
Tuesday, May 25th, 2010 AT 1:27 PM
CHOPPLEY101
Hi the engine light has not come on, so I checked the plugs and they had gaps you could get your finger through, They are shot as is the air filter, I have closed the plug gaps and given the air filter a good banging and it has solved the problem.I have only had the car two months so it is going to get a trip to the garage for a service. Thanks for your help.
Tuesday, May 25th, 2010 AT 2:04 PM
  • 109,885 POSTS
It sounds like a good tune up a good is in order. Let me know if you have other questions.
Wednesday, May 26th, 2010 AT 6:55 AM
