Car engine moves when changing car gear from D to R
8,400 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
HASSAMX.HABIBX
Hi, my car engine moves. i have gone to the mechanic he changed right side mount of the car the rest of the mounts he said are good. but when i went to the mechanic to see my car i changed the the gear from d to r the engine moved and i can feel because the engine moves too much. full engine move back and forth. i do not know what to do i have wasted too much money but still problem is there.
Jan 3, 2019 at 5:28 AM
Good afternoon,
Can you post a copy of the receipt of the work you had done?
There are three mounts and one engine strut which controls the movement of the motor.
https://www.2carpros.com/articles/how-a-motor-mount-works
Did he charge you for a diagnostic for this? if he did and it did not fix the problem, you are not responsible for his mis diagnosis of the issue. I would stop payments on your payment as this is his issue not yours.
https://www.2carpros.com/articles/replace-motor-mounts
Jan 3, 2019 at 5:57 AM
HASSAMX.HABIBX
He changed torque mount and right side engine mount.
Jan 3, 2019 at 2:25 PM
STEVE W.
  • 15,409 POSTS
Is there a way you could take a video and load it on this site? Some engines do move a lot others not as much. Perhaps seeing it move would help.
Jan 3, 2019 at 3:51 PM
