My car cuts off when making a stops
82,047 MILES • 2.0L • 4 CYL
ARNULFO ARANA
My car cots off when not hitting the gas or making stops at the light I have to put it on neutral for it to stay on my check light engine is not on
Jun 29, 2023 at 5:32 AM
  • 110,248 POSTS
This could simply be an engine vacuum leak or the throttle body needing to be cleaned.
First, check to see if there are any leaks.
Here is a link that explains how it's done:
If no leaks are found, I would next check and clean the throttle body. If it is excessively dirty, it can cause a stall at idle.
Here is a link that explains how that is done:
I attached the directions for servicing the throttle body specific to your vehicle below.
Try these things and let me know the results.
joe
Jun 29, 2023 at 4:01 PM
