my car crank crank it takes 1 minute to start..
GHOSTY92
I rebuilt my motor so I picked it up from the shop the car would crank and crank then start I told why is doing that he said one of my fuel injector is out so I took off went to another shop to check what was the problem he said a code came up thorny crank sheft was out so I changed it to a new one and the same problem was still thir code said crank sheft I did erase the code when I changed it it crank 1 minute it started....AT FIRST I TURN ON THE CAR WITH STARTING FLUID BUT NOT MINOR.HELP!
Sep 3, 2013 at 2:19 PM
  • 31,937 POSTS
I need to know what the code is? can you post it please.
Sep 3, 2013 at 10:36 PM
GHOSTY92
P0335 p1800 p0725
Sep 4, 2013 at 2:01 AM
  • 31,937 POSTS
Change the crank position sensor and also make sure that the connection plug is a tight fit and pins are ok and no corrosion.
Sep 5, 2013 at 10:20 PM
