Will not start, has no RPMs?
100,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
SMITHMS65
We have tested for spark, replaced the crank shaft position sensor and made sure the fuses are good. We have placed a machine on the car and it does not show any codes. What else could be the problem?
Jan 1, 2023 at 8:19 PM
  • 55,604 POSTS
So, does it have spark or no? If you have a shorted ignition coil it will shut down the coil driver inside the PCM. I would unplug all ignition coils and install one brand one coil to see if it sparks when cranking the engine over. Also, the code gathering that has done has it a CAN scan? This kind of scan does the entire car including the BCM and is more helpful than an engine code scan. You can get a CAN scanner (Controller Area Network) from Amazon from about $32.00.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
and
Amazon CAN scanner Link.
https://amzn.to/3G7mpFP
Also, they didn't make a Lesabre in 2020 can you please double check the year? Check out the images (below). Let us know what happens and please upload pictures or videos of the problem.
Jan 2, 2023 at 5:05 AM
