Transmission problem
100,000 MILES • 4.9L • V8 • FWD • AUTOMATIC
DSWANIGAN87
My car will start, but it will not move. The cluster lights up and stays stuck in park, but the shifter moves.
Jun 10, 2016 at 5:29 AM
HMAC300
  • 48,601 POSTS
scan for codes It may be the switch on transmission that tells cluster what gear you are in. a scanner would be able to point that out, but not one from an auto parts. A transmission professional will need to conduct the scanning for you with a professional grade scanner.
Jun 10, 2016 at 8:40 AM
