My brakes keeps locking up and causing my brake pedal to get hard to apply
1991 ACURA LEGEND
240,380 MILES • 3.2L • 6 CYL • FWD • AUTOMATIC
ROCKWOWLER718
My brakes keeps locking up and causing my brake pedal to get hard to apply. I replaced all the calipers, hoses, brake booster,master cylinder, front rotors, and the ABS unit. What else can be the cause of this problem?
Jul 2, 2017 at 3:18 AM
HMAC300
  • 48,601 POSTS
the ABS unit needs to be programmed to your car first if it was not. then from the sound of it a mechanic is going to have to use his scanner to open valves on ABS unit to bleed it. auto parts scanners and other inexpensive ones cannot do this.
Jul 2, 2017 at 4:59 AM
