my automatic jetta's shiftstick is stuck
AUTOMATIC
JETTAISUZUTOYATAOWNER
My Jetta's shiftstick does not want to move at all, I believe it might be a sensor with the brake pedal because the light that detects when I step on the brake does not turn off when I step on it. I want to know if there is an easy way to fix it or if I'll have to take it to the car shop, I haven't found anything on google and I was hoping someone here could help me.
Sep 7, 2015 at 12:06 PM
  • 31,937 POSTS
I need an engine size to access the correct wiring diagram
Sep 7, 2015 at 9:01 PM
EXOVCDS
  • 1,882 POSTS
If your brake lights also don't work, it could be that the brake light switch is the cause of both issues. Also check the fuse and the park / neutral interlock relay.
Sep 12, 2015 at 3:31 PM
  • 31,937 POSTS
Do you need the wiring schematic, if so sent the info I requested so I can get the correct info for you.
Sep 12, 2015 at 7:53 PM
