My AC keeps blowing hot air and engine overheats when AC is turned on
168 MILES • V8 • AUTOMATIC
ISABEL MARTINEZ
I took off the thermostat to avoid overheating. I already changed the fan clutch, radiator, AC compressor, the water pump, and some hoses. It still overheats when the AC is turned on with the thermostat on and blows hot air.
Sep 17, 2018 at 6:07 AM
  • 55,616 POSTS
The engine needs the thermostat so you will need to reinstall that and clear the codes. Next lets test the engine for a blown head gasket by following this guide.
This guide can help as well.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Cheers, Ken
Sep 18, 2018 at 9:13 AM
