Seems to be running fine but the A/C suddenly stopped blowing cold and the temperature gauge dropped.
Sep 19, 2019 at 3:07 PM
✓Experienced Mechanic
Good morning,
I attached a wiring diagram for you to view. Check the fuses I circled for power on both sides with the key on. This is not a visual inspection, it is a voltage check on both sides of the fuse.
As far as the temperature sender, it could be a bad sender unit. Check the sender for power with the key on.
Images (Click to enlarge)
Sep 19, 2019 at 9:28 PM
REDHULK
MEMBER
didn't address the issue?
Sep 23, 2019 at 12:21 PM
I do not understand what you mean? Please explain?
Sep 24, 2019 at 5:17 AM
REDHULK
MEMBER
Okay, so as i said the A/C quit blowing cold at the same time the temperature hand dropped to C. I drove the truck 10 miles home the next morning i drove about a mile and the temperature hand went from C to NORM then the AC started cooling again.
Sep 24, 2019 at 6:03 AM
I was addressing the temperature gauge first as that will effect the A/C operation.
Sep 24, 2019 at 7:47 AM
REDHULK
MEMBER
Oh, okay then.
Sep 24, 2019 at 12:54 PM
Let me know what you find. The 2 are connected.
Sep 24, 2019 at 12:59 PM
The PCM ties these systems together I would do a CAN scan toy see what comes up you may have a bad PCM. Here is a video. You can get a CAN scanner from amazon for about $45.00:
