My ac clutch plate flew apart
260,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
RELUCTANTEXAN
my ac clutch plate flew apart as if the magnets were trying to repel from the clutch plate itself.
Jul 29, 2014 at 6:20 AM
FREEMBA
  • 1,152 POSTS
You'll have to replace the entire compressor.
Have an a/c professional to evacuate the system, change the orifice tube, accumulator and compressor.then Vacuum the system, check it for leaks add PAG oil, then recharge the system.
Jul 29, 2014 at 6:48 AM
RELUCTANTEXAN
I know that but what caused it to fly apart. I have already ordered the compressor and it is a replacement part and the high pressure line connects differently so had to order that too. Good thing I have 2 sons that can fix it. Have a pump down pump and recycle container. have pag oil and freon 134A. I just want to know what caused it.
Jul 29, 2014 at 6:55 AM
FREEMBA
  • 1,152 POSTS
Sometimes the parts just fatigue and this can cause them to fly apart. Although its rare enough, it does happen. Usually it makes such a racket that it gets noticed before if flies apart. However, I'll seen then run quietly, yet still the fall apart as well.
Jul 29, 2014 at 7:03 AM
RELUCTANTEXAN
This was a rand new clutch plate off a brand new compressor. It lasted one hour. We just changed the clutch plate, as we did 2 1/2 years ago but that was a used one. It has something to do with the magnets repelling the lock-up ring.
Jul 29, 2014 at 7:25 AM
