A/C air blows warm air?
149,000 MILES • 3.6L • 6 CYL • 4WD • AUTOMATIC
CPAUL82
I checked my r 134a level and fuses/ relays: all ok. Then I pulled the connector off the compressor and checked for voltage while truck was running. I had 15 volts. Is this an indication of bad clutch coil?
Jul 7, 2023 at 5:33 AM
  • 55,749 POSTS
If the clutch is not rotating when the compressor was over 12 volts the clutch coil is bad, here is how to change it out. If they serviced, the coil separately, which some, don't, you will need to get the replacement compressor. here is a video and guide to help with instructions in images below to help you with your car:
https://www.2carpros.com/articles/replace-air-conditioner-compressor
and
https://youtu.be/4EqdrBVb0sY
Check out the images (below). Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
Jul 7, 2023 at 10:53 AM
