My vehicle cranks but will not start. There is no spark.
Feb 8, 2018 at 8:32 AM
PATENTED_REPAIR_PRO
✓Experienced Mechanic
Check if you have voltage to the coils at the black/orange wires with the key on run, if not check the CB-4 fuse in the dash fuse box.
Also check if you have voltage to the ignition control module black/yellow wire with the key on run and if not check the CB-3 fuse in the dash fuse box.
